but then if you're going to take control of boost away from the PCM via a MBC or EBC or WGA, you should add a AFR or EGT gauge in addition to the boost gauge to keep an eye on things. If you up the boost you should have some sort of monitoring devices such as the above gauges to keep things in check.
