quote:Originally posted by rszappa1
Feeling the road is good if you like it...It is not a vibration because if i go on newly resurfaced roads it is smooth as silk. I guess at age 52 I am looking for a smoother ride..dont get me wrong the tire is great especially in the rain and i will keep it on my PT...Put when it is time to replace I will go with a little softer and less agressive tread...
Ok... so probably a harmonic between the aggressive tread and some road surfaces.
Have you tried varying your speed? (Does it just keep getting worse as you speed up? Or does it only occur during a specific speed range)
Or... Have you tried varying tire pressure? A reduction to 30-32 psi might smooth things out and not put too much pressure on your gas mileage.
