Old 15 Jun 2006, 07:25 am
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
Only have 2 suggestions, could be a ground & or did you install bulbs with a higher wattage than 55 watts? There have been problems with using the higher wattage bulbs, it heats the wiring harness up and could be grounded out to the body. These are just guesses. Could the pin be bad that plugs into the multifunction switch? Good luck and let us know how you make out
