If the valve stems are ok, have the tires unmounted and clean the rim in the bead area. Some (not all) alloy wheels can oxidize and cause a leak. Are these new tires? If so, then go back to where you had them installed. The tire dealer should take care of it. Dont let them use a wire brush to clean the bead seat. A scotch brite pad will work and not cause more scratches like a wire brush. goood luck
Hey look guy, The closer you tailgate..the slower I go!
