Old 07 Jul 2006, 10:37 am
quote:Originally posted by kumachi
Hey Ken - did changing the plugs and wires cure the problem?
I have been having the same issue with my '04. I had the dealership change out the plugs and wires as well as had my injectors and throttle control cleaned. It was only a day or two later that the problem returned.
Took the car back to them - they drove all day couldn't get the engine to hesitate or stall.
So if you did change out plugs and wires and it worked - what plugs and wires did you go with, I don't think the ones they put in are doing the trick.
The best wires are Magnecore and Crane. I've never seen a bad post about them, only parise.
I used Cranes from RaceAndStreet.Com.
Plugs - If you don't have a turbo, you can use platinums for longer life. If you have a turbo, copper or irridium only.
