I'll try and help. I don't think your reading the correct fault codes. To obtain the fault codes your looking for, put the key into the ignition and turn it towards the window (forward) three (3) times without actually starting the engine. On the 3rd turn forward, leave the key facing the window and the codes will then show up in the center dial.
The "codes" that you were seeing is the PCM information codes that you see when you do a "Dial Test". That's holding the reset button IN while turning on the ingnition key. All the dials will go through a test and then give you some information codes.
