Victoria, first thing you should do is find your local janitorial supply store near you, they are most helpful for difficult stains in sensative material. what I would do as always is start out with the least aggressive cleaning solution possible. Since suede can color change easily you must be careful. take a clean bucket of plain water. get a bottle of all purpose cleaner, using a terri towel. wet it wet from the bucket of water, wring it out so its damp. first wipe down area withthe damp towel, then spray some all purpose cleaner on the entire area where the stain is, using the damp towel clean the area again. if the stain is solvent based this solution won't help, however if it is food based, it will work. if the stain still exsists after this approach,the janitorial store will have a solution for sure. Gary
