Good ideas. Have to call you Dr. GT Strangelove. hehee
The GT has a lot more intake plumbing than most cars. I was thinking of wrapping the tube going from the turbo (behind the engine) to the intercooler (in front of the radiator) with a foil heat shield. Same with the tube going from the filter box to the back of the engine. When all that tubing gets hot it must heat the air inside it.
Maybe removing that wheather strip is a better way to go or even a combo of the two.
The home improvment store may be the place to look for your air scoop parts.
flexable plastic yard drainage pipe and Y or T connector. Not sure if it will work. Just an idea.
