Sci-Fi's website has the filters that fit the PT:
Oil Filters
Below is a listing by manufacturer. The 2nd filter number listed (and/or followed by **) will be the longer and larger capacity filter, usually used in the GT or Turbo PT's but can be used in the regular PT's. As always, double check the part numbers if you have access to an oil filter catalog. Part number changes happen quite frequently or get outdated.
AC Delco
PF53
PFL400A**
Amsoil
SDF57
SDF34**
Casite
CF-3614
CF-213** or CS113**
Fram
ExtraGuard -
PH3614
PH3600**
ToughGuard -
TG3614
TG3600**
DoubleGuard -
DG3614
DG3600**
X2 -
XG3614
XG3600**
Hasting
LF157
LF135**
K&N
HP-1002
HP-2009**
Lee
LF2835
LF400**
Meijer
M22
Mobil 1
M1-102
M1-209**
Motorcraft
FL793
FL13A** or FL-400A**
Pennsoil
PZ21
PZ19**
Pronto
PO3614
PO3600**
Purolator
L10241
L20195**
Purolator Pure One
PL10241
PL20195**
STP
STPS3600**
TruFilter Oil Systems
TUD560
TUD738**
See Ultra Filter notes and warning below. It appears to be the same filter
UltraFilter
ULT560
ULT738**
Note: UltraFilter media are re-usable and cleanable. Filter media is T304 stainless steel 35 micron screen cloth and the exterior and end cap is made of 6061T6 Billet aluminum.
Warning: Typical or traditional oil filters trap particles between 6 and 20 microns. Re-usable filters only trap 35 micron or larger particles. So use re-usable and cleanable oil filters at your own risk.
Valvoline
VO25
VO23**
Wix
51348
51516**
I'd say to put the filters on eBay and use only the correct filters.
