Thread: How to Section
Old 23 Feb 2003, 05:42 pm
Lord Vadr Lord Vadr is offline
I have a EGT in my drag car amd you tap a spot in the manifold, usually runner 1 because that is usually the hotest, and screw the probe in with anti-seize paste.
The installion guide won't tell you how to hook up the power for each individuall car. For the gauges I want to install, you have two power inputs 12V constant and 12V that turns on when car turns on, and if you only want the gauges' lights to go on when you turn the car lights on that has to be spliced with different wire also
