Old 12 Sep 2006, 09:29 pm
littleblueGT littleblueGT is offline
Read "FLOW BACK CATCH CAN" for more information. The oil flows back into the engine from the catch can and does not require draining. As long as the unit is mounted higher than the breather fitting and at least a 45 degree angle it will work fine, you can run the other end where ever the intake fitting is located.
