Welcome, Gary.
First thing to check- that boots are fully seated - push hard 'till you feel/hear a click - they're tough. A little dielectric grease inside the boot helps.
Next I suggest you pull wire off # 4 (both ends) and swap with # 3 to see if it's wire or plug ( if you still get 304, it's plug, if it becomes 303, it's wire). It happened to me (only with plug 2) - after I swapped, light went away! I suspect I may not have had wire seated at one end or the other...
