Old 15 Oct 2006, 12:52 pm
littleblueGT littleblueGT is offline
I just installed the plastic intake manifold this week end, and it is really a pain in the ass! I have small hands and forearms and I had trouble reaching the 15mm lower support bracket bolt. Disconnect the battery before attempting to remove it as it is close to starter terminals!On the thermostat housing rotate the hose clamp towards the head as the plastic manifold sets lower than the aluminum manifold (much lower!)The new thermostats don't have the notches as the OEM ones do, so I had to cut them so the seal would fit properly. The seal has 3 bosses that fit into the notches, and for some reason the thermostats don't come with new seals! I bought the 180 deg. and the one called out for th GT, the 195 deg., but I installed the 180 deg. A turkey baster works great for coolant removal rather than draining too much and getting air pockets ( as suggested by pt cruise). Use compressed air to blow off the contamination around the injectors and manifold before you start, then use a vacuum to clean threaded holes and ports when you have the manifold off.
The plastic manifold does stay much cooler than the aluminum manifold which should help in stop and go driving.I left my NGK iridiums (heat range 6)gapped at .045 to get a better comparison between the two manifolds, and it worked just fine!It does seem to pull harder at hegher RPM range, but not noticeable at the lower range. This is a week end project so give your self enough time to do the job right!
