Old 07 Nov 2006, 11:18 am
bigdogdad bigdogdad is offline
Here's a list from Punch back in 2003, seems to be alittle different, especially the lower few numbers but the first list above has tons more in the higher numbers. Do some cut and pasting and print out and put in glove box.
This should be a sticky as mention. Get your code definition and your good to go, if you don't understand, then come back and post your problem.
Posted - 10/13/2003 : 10:26:05 PM
OBD II Fault Codes Reference Guide
The Diagnostic Trouble Code numbering follows a standardized structure. All Diagnostic Trouble Codes have a letter followed by a 4-digit number (e.g. P1234). The first letter indicates the type of code:
P = Powertrain
C = Chassis
B = Body
U = Network Communication
The remaining 4-digit number specifies the problem within that system.
P00XX Fuel and Air Metering and Auxiliary Emission Controls
P0010 “A” Camshaft Position Actuator Circuit (Bank 1)
P0011 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 “A” Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 “B” Camshaft Position - Actuator Circuit (Bank 1)
P0014 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 “B” Camshaft Position -Timing Over-Retarded (Bank 1)
P0020 “A” Camshaft Position Actuator Circuit (Bank 2)
P0021 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 “A” Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 “B” Camshaft Position - Actuator Circuit (Bank 2)
P0024 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 “B” Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
BACK
