Old 09 Nov 2006, 04:10 pm
From the "forbidden Forum":
This is the updated Flight Systems info from the SRT forums. I guess Stephanie is now in charge of this department. Here it is:
Hello,
My name is Stephanie and I am from Flight Systems, the company that supplies you with your turbo kits. If you have bought a used stage kit and need your vin number reflashed into it you can send your pcm to me and I can reflash it for you. I can NOT reflash stock pcm's. As you should know, if you do not reflash the module and try to install the pcm in your vehicle without changing the vin, your vehicle will not start. The charge for this will be $30 plus s&h plus the COD charge. I can either ship it back to you overnight air, which is expensive or ground which will only cost $4-5 more on top of the $30 plus the $7 charge for COD. The cost for everything will be around $43, which will come COD (collect on delivery). Everything will be sent back using the carrier UPS, no exceptions. When the driver drops your pcm off you must give him a check or money order made out to Flight Systems, for the exact amount. Once I ship your pcm out, I can send you a pm with your tracking number and total COD amount. The address you will need to send it to is:
Flight Systems
1040 East Maple Road
Troy, MI 48083
Attn: Stephanie/Reprogram
Please make sure to put inside the box your vin number, return address, a telephone number I can reach you at in case of any problems,your name on the forums, and how you would like it sent back to you; ground or overnight. Please make sure the pcm is packaged properly, any damage that happens on delivery to me is not my respondsibility. Let me know when you are sending it out to me by pm so I know when it should arrive. I will ship it back out to you 1-2 days after I receive the kit. If you have any questions, you can pm me as well. Have a great day!!
Stephanie
Flight Systems
Parts Department
Sorry, no phone # or email...
