Old 21 Nov 2006, 05:09 pm
fritz_t_coyote fritz_t_coyote is offline
quote:Originally posted by ruzz1
anybody has this experience? everytime step on the accelerator pedal the engine has some sort of whining noise to it? cud it be an indicator of the auto trans mission problem? its get slightly louder at high speeds.
mine has 70k miles on the engine 2001 baseline model.
OK:
0- Is the whine coming from your audio system (turn off the radio...) If so: your alternator is getting old.
1- In driveway, hood open, transmission in Park, Parking Brake Set.
== have a helper start the car and listen for the whine as they rev the engine== is the whine heard? Where is it coming from?
then have them crank the steering wheel lock-to-lock (all the way left and right) Listen to the belt squeal (a little squeal at full lock is normal, as the power steering comes up against the mechanical limits of the steering system.) If it squeals continuously it is a belt problem.
If the problem ain't there in neutral, it =might= be a transmission problem.
2- on an empty straight road:
accelerate until you hear the whine, then shift to Neutral and back off the gas. Do you still hear the whine? Could be wheel bearings...
3- Automatic Transmission? Maybe.
Get it to a mechanic you trust.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
