Welcome.
I Haven't done it, but to get at the door speakers:
The front door panels have a screw under the trim panel at the upper rear corner, two along the bottom and one behind the door open handle. Remove the two bolts from the door close handle and then unsnap it all the way around. Disconnect the door open handle linkage and power window connector.
Come back if you want to do the ones in the dash, too - removing the dash is more involved.
