According the manual in the 2003's, you must remove the keys from the iginition switch, lock the door using either the door key, power door lock switch, or the Keyless Entry Transmitter and close all doors. The indicator light in the instrument panel will flash rapidly for 16 seconds. During this time, if a door is opened, the ignition switch in turned on, or the power door locks are unloced the system with disarm. After 16 seconds, the system is fully armed. No method is listed to alter the 16 second timing.
2003 Almond GT, body colored rear splash guards, hood struts and front license plate frame, rear MOPAR door sills
