Next biggest bang for the buck would be either a Stage 2 WG from an SRT4 or an AGP wasgate. At the same time add a 2-stage manual boost controler and a boost gage. With those 3 items you can up your boost to 17 lbs. boost without pulling timing. Figure about 7-8 HP for every pound of boost you add.
Deen
