Old 17 Mar 2007, 06:42 pm
littleblueGT littleblueGT is offline
I FOUND NO PROBLEM WITH THE WEAR OF THE ROTORS, BUT I DID NOTICE THAT MORE PEDAL PRESSURE WAS REQUIRED TO STOP.THE CERAMICS DON'T FADE AS THE ORIGINAL OEM'S, HAVE MUCH LESS DUSTING, DON'T MAKE NOISE,DON'T FADE AS DO THE OEM'S, BUT YOU DO HAVE TO PUSH HARDER ON THE PEDAL TO STOP! THE STOCK ROTORS ARE VERY SOFT, BUT IF YOU BUY AFTER MARKET THEY SHOULD WEAR BETTER.DEPENDS WHAT YOU ARE LOOKING FOR.
