Old 19 Mar 2007, 02:17 pm
purple04 purple04 is offline
Check fuse 18 (15 amp) in the PDC (underhood), and Fuse 14 (20 amp) in the fuse block (left side of dash). Ground is located in rear center of dash, but unless someone has messed around there, I doubt that's the problem.
If the fuses are okay, you could pull the console to check power and ground at the unit, but at that point it may be the whole thing. Good Luck.
