Old 29 Mar 2007, 04:44 pm
CREWZIN CREWZIN is offline
quote:Originally posted by Mo_Posse
I've got an '02 non-turbo, and the A/C just stopped a few weeks ago. How do you know if the clutch is working or not to test?
Thanks.
Turn the engine on and you should here the compressor clutch engage when you set the air-conditioning switch to on. If the car is cold, the fan should come on when the air-conditioning comes on no matter what the temperature is. As Purple04 and QSD said, other problems might be in play like being low on R132 gas. If that's the case, the high pressure switch won't let the air-conditioning system work. Most shops will test everything for free.
2000 PT. 96K miles, Original Owner
