Thread: Problems
Old 17 Nov 2002, 01:58 pm
CREWZIN CREWZIN is offline
Sounds like you've run into your share of problems. The dealer feedback on improper tire inflation causing the wobble is BS. A lot of people have been having problems with the OEM Goodyear tires. Try rotating them by putting the front tires on the rear and see if that helps. Your codes seem to be normal from what I can see from doing a search on "codes" in this and other forums. These codes your seeing don't match up with normal trouble codes and it's been suggested that they show up only on "02" models and refer to manufacturing software revisions. Don't know if that eases your mind, but there are a number of people seeing the same codes and it's unlikely your all seeing the same problems. On your water leak...you should be still under warranty so have the dealer find out where it's coming from or get under the car and see if you can pinpoint the leak. The air-conditioner leaks from the right side (I think), but if it's pure clear water your seeing, it could be from the condensation while using the air-conditioning...remember, even if your on the defrost mode, I'm pretty sure the compresser runs to give you moist air to demist the front windshield. The smell from your vents should also be a known problem by your dealer. Some people have fixed it with a shot or two of Fabreeze, others put in a filter for the incoming air and in one case, the dealer put in a whole new unit.
Edited by - crewzin on 11/17/2002 12:01:04
