Old 26 Nov 2002, 01:02 am
JoeCee JoeCee is offline
They are actually rather easy to install yourself. The hardest part usually ends up getting the wiring through the door grommet to the inside of the car. The aftermarket actuator are just a little solenoid with a rod attached to it. All you do find your door lock rod inside the door, and then mount the solenoid with 2 screws and attach the solenoid rod to the doors rod, sounds harder then it really is. The wiring is rather simple as well.
