If you pull straight up and wiggle on the airbox it will pop out of the rubber grommets that hold in place. You have to loosen the clamp and pull the rubber hose that connects the air box to the throttle body. The whole airbox will come right off.. If you decide to take a look under it just make sure you loosen the hose on the airbox side because there is an air temperate sensor in the hose.
