Old 24 Jul 2003, 03:30 pm
JohnM JohnM is offline
Cal Cruzer - I see that I didn't answer the question you asked. You want to see the location of the mounting (nuts), not the nuts themselves. The sway bar mounts to the back side of the rear twist-beam axle. The mounting points are on plates that are welded to the axle just outside of the spring perches. You'll see the hole for the mounting bolt easily when looking under the car from the rear.
