Horn - High Note - Part # 4671747-AB
You will also need a Metric M6-20 (6mm X 20) bolt to put it on with. A self-tapping, flanged one would be a plus. If you have to go with a standard (non self-tapping) take the bolt out of the existing horn bracket, and use it to thread the hole that is there for the second horn (not threaded). It is a plastic mounting area, and it will thread easily. Then, you can use the standard bolt. If your dealer can't provide the bolt without a part number, go to a motorcysle shop. They have been dealing with metric threads for a long time...
The location is there in plain sight once you remove the right front fender well cover. (Three 7mm head (3mm) machine screws. The connector is taped to the harness; just remove the tape, and plug it into the new horn.
I turned the wheels all the way left to remove the screws on the inner fender cover, then turned them all the wat right to install the horn.
Hope this helps.
