Alan, this may or may not apply to you. But next time it happens, try turning on your wipers. If the wipers also don't turn on.... your problem is with the ignition switch. To verify, when it happens with your car running, turn your ignition key towards you as if you are shutting the engine off but move/rotate .5 to 1 mm. without shutting the engine off. If your radio and wiper turns on, than for sure it is your ignition switch assy.
Electrical part of the switch or the whole switch assy. may need to be replaced.
03 Silver GT Turbo 5-Speed
