The turbo and Manifold from the GT will bolt right up, all you need to do is run the lines (oil, coolant), and change the fuel system to a return style and add in a RRFPR. W/o an intercooler you can safley run 5-6PSI, w/ an intercooler you can run 8-9PSI. That should put you around 200WHP.
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
