quote:Originally posted by Puck
quote:Originally posted by tangerinedream1845
....he just shook his head [xx(]and said it is a ground problem and it would not show up on the computer print out from the tests so i drove the car back in to the shop he spend all of 2 minutes pulled the ground wire off of the body used a file to remove the paint then he put a yellow conductive paste on it to make sure no rust starts and rehooked up the cable ..... problem solved
Is this the ground wire from the negative terminal of the battery to the car body??
Puck
tangerinedream1845 do you know which ground they repaired?
