Old 01 Feb 2004, 06:22 pm
javi21 javi21 is offline
Send a message via AIM to javi21
Hello IRPT!
Thank you very much for this quick and precise answer to my problem!
However, since I am not a very handy person with cars (just the basics) I would like to know if it is possible to repair this kind of small dent without removind the bumper, do you know of any technique?
Thank you once again,
-Javi
quote:Originally posted by IRPT
Welcome to the forum javi21. Here are the instructions for removing the grille, front fascia and bumper reinforcement.
GRILLE REMOVAL
(1) Open hood and support hood on prop rod.
(2) Remove screws attaching grille to radiator closure
panel (Fig. 5).
(3) Pull top of grille down and to disengage hooks
from fender.
(4) Remove grille from vehicle.
INSTALLATION
(1) Place grille into position on vehicle, engage
lower hook into fascia first, then engage middle hook
to fender, then engage top hook. (Fig. 5) .
(2) Install screw attaching grille to radiator closure
panel.
(3) Close hood.
FRONT BUMPER FASCIA REMOVAL
(1) Remove Grille Attaching screws.
(2) Remove Grille.
(3) Remove nuts attaching front bumper fascia to
bottom of fender flange (Fig. 2).
(4) Remove fasteners attaching fascia to fender
flange (Fig. 3).
(5) Remove air dam fasteners from crossmember.
(6) Remove splash shield attaching screws.
(7) Remove fascia from vehicle.
INSTALLATION
(1) Position fascia on vehicle (Fig. 2).
(2) Install splash shield attaching screws.
(3) Install air dam fasteners to crossmember.
(4) Install fasteners attaching fascia to fender
flange (Fig. 3).
(5) Install nuts attaching front bumper fascia to
bottom of fender flange.
(6) Install Grille and attaching screws.
FRONT BUMPER REINFORCEMENT REMOVAL
(1) Remove grille (Refer to 23 - BODY/EXTERIOR/
GRILLE - REMOVAL).
(2) Remove front fascia (Refer to 13 - FRAME &
BUMPERS/BUMPERS/FRONT FASCIA - REMOVAL).
(3) Remove bolts attaching reinforcement to the
rail assembly and Remove reinforcement (Fig. 1).
(4) Remove bumper reinforcement from vehicle.
INSTALLATION
(1) Place bumper reinforcement in position (Fig. 1).
(2) Install bolts attaching reinforcement to rail
assembly.
(3) Install front fascia (Refer to 13 - FRAME &
BUMPERS/BUMPERS/FRONT FASCIA - INSTALLATION).
(4) Install grille (Refer to 23 - BODY/EXTERIOR/
GRILLE - INSTALLATION).
Good luck.
