Old 16 Feb 2004, 12:37 pm
PTBlue PTBlue is offline
I am having the same problem on my 2001, but your suggestion doesn't seem to be working for me. I noticed that the original person who placed this topic had to replace his ignition lock cylinder. Are you still having issues with this? My issue is intermittent but for now seems to be locked up. I have tried the wheel turning, brake pressing, pushing the key in more, turning to the left and then the right, you name it. The only thing that has worked for me in the past was luck. Any suggestions?
quote:Originally posted by relytgerg
Actually, the problem appears to be completely unrelated to steering lock. I'm convinced there is some minor damage to, or defect in the actual ignition cylinder. Here's why I'm sure of this: Locking the steering wheel or turning it doesn't normally help clear the problem. I am familiar with this problem on this and other vehicles and the symptoms are different.
Curiously, what does work, everytime, is to apply gentle pressure to the key as if pushing it further into the ignition cylinder. When you do this the cylinder springs in and back out ever so slightly. Then the key works - every time.
It's still a mystery to me, but I'm glad that I have no troubles starting it for now.
Thanks all.
