Stage 1 Installed Question
For all you guys that installed your Stage 1 kits.
The instructions have no mention of thermal tip protectors, and the kit we installed had none pre-installed, as were the injector seals.
Thermal Soak can cause the injectors to become overly hot and coke the contained fuel much as the turbo will coke the oil on the turbo bearings.
I am inquiring about EVERYONE'S injectors... did anyone recieve injector tips(clear plastic)on their new injectors, or were you successful in removing the tips from the original injectors and installing them on the new injectors without instruction?
This could be a serious issue, PLEASE RESPOND.
Thank You.
Kirby
