Old 14 Mar 2004, 11:39 am
quote:Originally posted by ElectricBlueGT
quicksilverdon,
I know because I can open the rear door and press on the vents and the rattle or buzzing stops.
I have a problem with foam or two-sided tape on body panel openings: water retention. Anytime you can retain water on a body seam or opening, it's an invitation for rust to start.
Scott
Silicone caulk then? rubber o-rings under screws?
