Does it look like the water leak could originate from the door sill area??? Just wondering, because I think the rear window washer fluid hose runs thru that area and it might be leaking. It's bundled into the wiring harness that's located on the driver-side floor. Well at least I think it's the rear window washer fluid hose. It's 3/8 dia rubber hose running the full length of the car to the rear. So, that could be leaking causing dampness even during dry weather, but heck I'm probably wrong.....
