Actually the service manual does mention using distilled water (see below):
From the Service Manual:
COOLANT
DESCRIPTION
CAUTION: Use of Propylene Glycol based coolants
is not recommended, as they provide less freeze
protection and less corrosion protection. Do not
mix coolant types. If coolant other than Mopar®
Antifreeze/Coolant, 5 Year/100,000 Mile Formula or
equivalent is added, the mixed coolant will have a
reduced service schedule.
The use of aluminum cylinder heads, and water
pumps requires special corrosion protection. Mopar®
equivalent ethylene glycol based coolant with corrosion
inhibitors (called HOAT, for Hybrid Organic
Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when
mixed with 50% Ethylene Glycol and 50% distilled
water to obtain a freeze point of -37°C (-35°F). If it
loses color or becomes contaminated, drain, flush,
and replace with fresh properly mixed coolant solution.
Mixing of coolants other than specified (non-
HOAT), will reduce the 5 year/100,000 mile corrosion
protection.
