COPTZER,
The stock BOV is located on the compressor housing. Here is a pic of the turbo (on a SRT-4 Intake,) with an Arrow pointing to it.
Im putting my HKS BOV on tomarrow , I've decided to put it on after the IC before the throttle body. See pic below. After doing alot of research on this topic, Ive found that it definatly wont hurt to run both BOV's. So I just need to run another vacumn line to the HKS BOV.
I will let you know how things turn out tomarrow.
ATPturbo.com sells a kit for the SRT-4 that includes a Upgraded Pressure Pipe and BOV Flange, Unfortunatly it does not fit the GT. It would be nice if someone made a similar pipe for the GT as well. With their kit, they put a check valve on the existing stock BOV, they have a great install PDF located here,it includes instructions for bypassing the stock BOV...
http://atpturbo.com/support/SRTUPPINSTALL.pdf
Hope this helps you out,
Matt
