quote:Originally posted by BB
quote:Originally posted by Capt Kidd
[8)]Hi, I have a base early model 2001 and have been towing my 2000 lb.
I wonder why DC sets the limit at 1000 pounds? Frame too week for heavy towing?
BB
There is no frame on the PT- its a unibody. The tow weight is base don GCWR_ Gross Combination Weight Rating, the weight of the PT, occupants, load, fuel and the total weight of the trailer.
The PT has a GCWR of about 4500 pounds, set by drive-train, cooling, braking, suspension, ...
Subtract 3200 pounds for the PT, 300 pounds for 2 people (average), that leaves 1000 pounds for the draw weight.
Turbo's require extra precautions- the extra heat generated by the always-on turbo, if the weight is enough and the engine decides that the boost is required, may be too much for the turbo, engine, and other components. I would personally keep the tow weight to about 800 pounds or less with the turbo.
S
