Old 20 May 2004, 08:28 am
quote:Originally posted by saxonburgcruiser
Buy the kit, you will need it eventually. Depending on conditions, cleaning and re-oiling every 20-30K should be sufficient.
Agree on kit. It contains a spray cleaner, and their "special" oil. The directions state much higher miles, that when it's dirty it actually filters better, but I have cleaned mine twice, and it's due again with 73,000+ miles, so 20-25,000 miles is a good guess.
It says to remove debris first (I use shop vac). Spray cleaner & let sit. Stick hose on inside and wash out. Shake & let dry, then re-oil. You'll see after cleaning, it's almost white - it's the read oil that gives it color.
