Old 28 May 2004, 12:58 pm
Ctown Ctown is offline
quote:Originally posted by Sci-Fi
Yes, definitely have them fix all the electrical problems before your used car warranty runs out. Use everything multiple times and often to make sure it all works fine.
For number 2, have the dealer change the door seals. They will install the 2002 seals which are better and won't fall off later. If they won't change it, then use 3M Super Weatherstrip Adhesive Yellow #08001 or 3M Super Weatherstrip Adhesive Black #08008.
While you have the 60 day/3000 mile warranty, then have them change all the stuff that will need changing soon (timing belt, clutch, brakes, etc). Also, check to see if any/all the recalls/tsb's have been performed on your PT. If not, then have them do it or find a closer dealer that will honor the warranty.
