Thread: Fog lights
Old 29 Apr 2003, 11:41 am
Gear_Head Gear_Head is offline
I have installed a set of Eaglite gold color xenon lamps in my fog lamp housings. These lamps were purchased from www.midnightmoose.com
These are 9006 (65 Watt) gold color xenons. I have had them in for 3 months now and show no damage to the reflectors or the lamps themselves. 65 watt is the max that you can go w/xenons in the foglamps due to the small size of the housings. Any higher (even 80 watt) will lead to heat damage to the lamp and/or reflector. There is also a 55 watt model of the gold lamp available. Following is a listing of the lamps used on my cruiser. All have been in for more than 6 months (fogs only 3 months) without damage. I turn my fogs on whenever the headlights are on.
1. High Beams - 9005XS Eaglite Xenon 100 Watt
2. Low Beams - 9006XS Eaglite Xenon 80 Watt
3. Fog Lamps - 9006 - Eaglite Xenon (Gold Color) 65 Watt
PS: The XS version of the lamps are stated to be different than the nonXS version in ways other than the 90 degree bend. The wattage is the same so I don't know what the actual other differences are. The 9006s are used in the fogs so that when mounted properly the connector points down due to their location down by the road. The connectors are water tite (O-Rings) but the 90 degree down angle for the connectors completely waterproof the connections.
MidnightMoose has the best prices for replacement lamps that I have found.
[8)]
