Old 13 Apr 2007, 06:53 am
Johns Steel Blue's Avatar
Johns Steel Blue Johns Steel Blue is offline
Default Re: Windscreen Washer
Originally Posted by deanc View Post
I don't know if anyone else has had this problem, but I am experiencing very poor strength from the water jets to clean front and rear windows. Nothing at all coming out of rear one. I can hear the motor running but not much water comes out.
Any help/advice appreciated.
Many Thanks
More than likely they just may be blocked from sediment/calcium if you put in water. I'd remove the plastic tube leading to the jet under the hood and then try and see if it flows. If it does, the sprayer itself is probably blocked up. I would think you could remove then and clear them with something like CLR or Limeaway.
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
