Old 16 Apr 2007, 06:59 am
CREWZIN CREWZIN is offline
Default Re: Console flood lamp replacement
Ray,
Good question. I just took a look at it and can see that it's inclosed in an oblong black piece that looks like it prys out. There's a really small tab on one end and when I move the tab the whole oblong black square does move a bit and I think it will drop right down to replace the bulb but mine is stuck pretty tight and didn't want to force it. It's working now and don't want to break it in case someone comes along and says that you get to it through the center console, which might not be a bad idea. Removing the center console is easy and from there all the panels can come out to give access to the inside where the light might be.
