Old 01 May 2007, 11:39 pm
BostonBoy BostonBoy is offline
Question factory subwoofer cutting out! need help!
hello all,
currently have a 2001 chrysler pt cruiser with factory single cd/radio and have installed the factory subwoofer available from chrysler.
for some reason, i am getting a problem with the unit causing the radio and sub sound to cut out for a fraction of a second whenever there is a draw on the battery. if i have the wipers on, each time they start up i lose sound for a second. same when i hit the brakes (brakelight), power windows , etc.
i have rechecked all grounds. tried wiring the power to the amp away from the radio (instructions call for it to be powered off the cigar lighter located on the console). have removed grounds, and reinstalled.
the problem occurs after the sub and radio have been on for a few minutes, or when the unit is really cranked up.
i have disconnected the power and ground to the sub and the problem still occurs, which leads me to believe it must be the harness connection somehow, or a grounding condition.
currently there are two wiring harnesses that plug into the back of the factory cd/radio, with a separate power feed and ground attached to the radio back.
the amplifier/sub power off a relay attached to the harness. perhaps a ground at the relay? (unit seems to work whether it is grounded or not, possibly because the radio is grounded separately?)
if anyone can suggest other things for me to check, it would be most appreciated.
the factory sub is the 80watt model, not the 2001 50 watt model, so a standard metra harness is used to tap into the right and left rear speaker feeds. i generated a wiring harness drawing indicating how it all is put together, incase someone could look at that and say "bingo!-that's what is wrong!)
thank you in advance.
dave
