Old 08 May 2007, 08:18 pm
gipper65 gipper65 is offline
Default Convertible passenger side windows don't go down
I have a a 05 PT cruiser convertible. Both passenger side windows do not go down. there is no movement at all not even the little down when you open the door.
I have checked all the fuses none indicate passenger side only and none are blown. I have replace the switch no joy.
Here is a little history it was miss firing and the service engine light was on. Before I drove to my fathers house (he had the engine scanner) I disconnected the battery (positive terminal) just to see if clearing the computer would fix the problem. again no joy (it was worth a shot (maybe))
The engine code showed miss firing on cylinder 3 switch plugs 2 and 3 the problem moved so I replaced the plug. What does this have to do with the windows not working maybe nothing but immediatly after changing the plugs the windows stopped working and I don't really believe in coinsidence. I was wondering if maybe I reset something disconnecting the battery. I can't say for sure that the windows worked between changing the plugs and disconnecting the battery.
Any ideas would be appreciated
Thanks
