A little background. The wife has a 2001 Cruiser w/auto trans. I drove it home and parked it, tried to start it the next day and nothing. Gauges, lights, fuel pump all work but nothing out of the starter. Starter cranks good per the starter solenoid test (Pg. 8B-2) step 7. Replaced the original battery just because, (which was still working fine
) no help. Going through the 2001 service manual starting system both the “starter solenoid” and “starter relay” diagnosis & tests check good. Doing the “relay circuit test” steps 1,2, & 3 check good. At step 4, I’m not getting battery voltage at terminal 86 (or any other terminal) in the start position.
Note; per Fig. 2 and the chart below it on page 8B-3 it calls out terminal 86 also being pin 1.
(lost yet?
) Wire diagram on page 8W-21-2 shows a circuit between ignition switch terminal 6 and starter relay terminal B4.
Where the heck is terminal B4 on the relay????
I have a yellow 14 gauge wire between terminal 6 of the ignition switch and the starter relay pin 2 or terminal 85.
Any other ideas on where to look?
Thanks, Steve
