  #15 (permalink)
Old 20 May 2007, 06:34 pm
littleblueGT littleblueGT is offline
Default Re: Pop and backfire,2500-3000 RPM
The cam position sensor will cause what was described earlier, but I found that the map sensor will also cause the same problem. Check for codes by switching the key 3 times to on/off. The cam sensor is easy to replace, and so is the map sensor. You may want to check your intake manifold as after the "pop" you could have damaged the map sensor and split the manifold.
