Re: Pop and backfire,2500-3000 RPM
Originally Posted by elacua
i have the same issue ,but i left it alone cause ithought it was a governor that cuts off at 2500 rpm so we wont blow the engine(factory) .Please correct me if i am wrong,cause this was my believed.
No, the cutoff is around 5,800 RPM - near the red line on the tach. In Neutral, it is is much lower, but in gear, you should ge able to rev well past 5,000 RPM.
