Old 25 May 2007, 09:12 am
littleblueGT littleblueGT is offline
Default Re: 180 degree thermostat question
Stant #13788, get it at Pepboys, Kragen, Autozone etc. Be careful with the OEM seal as the new stat doesn't come with one. You will also have to notch the stat in three places (same as OEM stat) to fit the seal, and drill a 1/16" air bleed hole. A turkey baister( squeeze bulb on a tube) works very well in removing coolant.Put the coolant into a container, and remember what ever you took out has to go back in. Allow plenty of time during refill of coolant to purge the air, or you will over heat.
