Thread: Two Sided Tape
Old 02 Jun 2007, 07:29 pm
MOPAR43 MOPAR43 is offline
Default Re: Two Sided Tape
I have used 3M two-sided tape with no bad experience. The important thing that I echo is surface preparation as being the key. Also, the temperature of the surfaces is also important; my rule is to not apply anything unless the air temp is at least 65 degrees.
I have NEVER had an item come off my cars and I have been using the product on a total of four cars in the last six years.
Remember, the factory uses the equivalent of two-sided tape, too. My advice, is if you can use a screw or a clip, use it. Otherwise feel free to use tape everywhere else as long as surface prep and temperature guidelines are followed.
P.S. Be sure to always store your materials at room temperature whenever possible!
Good luck!
2005 PT GT Turbo HO Autostick Convert. --- Bauhaus Progressive Rate Lowering Springs 2.0" frt/1.75" rear, Tokico HP Blue Struts/Shocks, Freedom Front Strut Brace, K&N Filter, Crane FireWires, MOPAR Turbo BOV, TOYO PROXES TPT 215/50/17 HP Skins, Sylvania Silverstar Headlamps, IPCW Clear LED Taillights, TYC Back-up Lights, 115db Airhorn, 13" Billet Radio Antenna w/ chrome bezel, Chrome: Fuel Door Cover, Trunk Lid Struts, Door Handle Cups, Door Spears, Hood Portholes, Washer Nozzles, GT logo valve stem caps, Steering Wheel Spoke Trim, NEW! Chrome Upper body trim, 30% window tint side and rear, Sirius One Radio, factory GPS.
Other MOPAR in our family: 2005 Pacifica Limited AWD
Past Mopars:
2003 Cruiser PT GT Turbo 4dr and fifteen others back to (my first and favorite) 1965 Plymouth Satellite 426 Hemi Conv't.
